Set paramStr in Maxscript
bertv
bertv
I have a problem with formatting a paramStr:
The code below works perfect.
But I want to set the tooltip in the paramStr directly instead of using a variable.
 Because I'm using the paramStr in a dynamic created rollout.
This works:
local nameSwatch = "swatch_" + (counter as string)
paramStr:(
"fieldWidth:"+swatch_width as string \
+" height:"+swatch_height as string \
+" pos:["+swatch_x as string+","+swatch_y as string+"]" \
+" color:" + col_line[2] as string \
+" modal:"+true as string \
+" toolTip:'toolTipData'"
This isn't working with the custom tooltip set to myTooltipText?
paramStr:(
+" toolTip:" + "myTooltipText"
Any ideas,
denisT.MaxDoctor
rcg.addControl #button #reset_bt "" paramstr:("width:22 align:#left offset:[-6,0] tooltip:\"Reset\"")
... or use stringstream for dynamic string creation:
ss = stringstream ""
format "width:% align:% offset:% tooltip:\"%\"" 22 #left [-6,0] "Reset" to:ss
_str = ss as string
rcg.addControl #button #reset_bt "" paramstr:_str
bertv
Thanks Denis,
Worked perfectly
I implemented as following using your suggestion:
			format "fieldWidth:% height:% pos:% color:% modal:% tooltip:%" swatch_width swatch_height ("["+swatch_x as string+","+swatch_y as string+"]") (col_line[2]) true ("\"" + col_line[1] as string + "\"") to:ss
			_str = ss as string
denisT.MaxDoctor
format is to convert a value to string ... so it can be:
format "fieldWidth:% height:% pos:[%,%] color:% modal:% tooltip:\"%\"" swatch_width swatch_height swatch_x swatch_y col_line[2] true col_line[1] to:ss
bertv
Thanks Denis,
Neat code
