Select same track across multiple unique objects in the track editor
ldotchopz7FPNL
ldotchopz7FPNL
I have an alembic file character made of hundreds of unique objects, i want to retime them using the playback graph and instance their keyframes across all objects, but since the objects are not instances i cannot select them all at once to paste the keyframes. I can make the Alembic Playback Graph appear in the track editor for all objects but then i still have to select the Playback Graph tracks 1 by 1. is there a script or a way to select the same track for mutiple objects so i can copy and paste their keyframes?
denisT.MaxDoctor
fn selectTrackInstances obj: =
	if (t = trackviews.current) != undefined do
		if obj == unsupplied do
			for k=1 to t.numSelTracks() do exit with obj = t.getselected k
		if isvalidobj obj do
			first = on
			for k=1 to t.getnumTracks() where (t.gettrack k == obj) do
				t.selecttrackbyindex k first
				first = off
/* Using:
selectTrackInstances()
/******* MCR version for Drag-n-Drop to a Toolbar:
		local obj = undefined
			first = on
				first = off
ldotchopz7FPNL
Hi thanks for the reply! When i run the script nothing seems to happen.
Is this script supposed to select track instances? Because what i am trying to do is select the same track of unique objects so i can then paste keyframe instances onto them instead to selecting them 1 by 1
denisT.MaxDoctor
you must select at least one track so the script knows what to look for.   .... and maybe you need to expand all the tracks to see the sub-tracks.
ldotchopz7FPNL
A script for $10 came out recently which solved this issue nicely for anyone facing the same problem in the future.
Thank you for you script too @denisT.MaxDoctor
https://jokermartini.com/product/bulk-editor/?unapproved=48050&moderation-hash=1f0287decd903e8755765...
