Select all objects with same Material Modifier ID
n_stylee
Message 1 of 8
n_stylee
Hello i have this script that is selecting all and only objects with turbosmooth  - 1 interactions
select (for o in geometry where try (o.TurboSmooth.iterations == 1 ) catch(false) collect o )
How i can modify it, so it will be selecting all objects that are having Material  Modifier  applied  with a  certain  ID ( lets say only id-3   ) ? Somehow it works with  other modifiers like Bend - with certain angle but not with Material Modifier.
Replies (7)
Message 2 of 8
denisT.MaxDoctor
for node in geometry where (m = node.modifiers[Materialmodifier]) != undefined and m.materialID == 3 collect #(node, m)
Message 3 of 8
n_stylee
Thank you for fast answer but its not working - it doesn't select anything .
Message 4 of 8
denisT.MaxDoctor
I charge 10 bucks for each node selected... Maybe it would be cheaper to find out how to do it yourself?
Message 5 of 8
MartinBeh
Just look at the code you posted and Denis posted...
All you need is
select (for node...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 6 of 8
n_stylee
select ( for node in geometry where ( m = node.modifiers[Materialmodifier]) != undefined and m.materialID == 3 collect #(node, m))
nothing 😞
Message 7 of 8
MartinBeh
nothing 😞
because Denis is thorough and collects not only the node but also the modifier... 😉
Try this:
select ( for node in geometry where ( m = node.modifiers[Materialmodifier]) != undefined and m.materialID == 3 collect node)
Message 8 of 8
n_stylee
Thank you so much it`s working!
