scripted network rendering and bitmapIO settings
12:59 AM
So I have a script that I have developed for submitting max jobs to backburner. (using the NetRender Interface) When using this Interface, the output file type is derived by the file extension on the job.frameOutputName. I have found nowhere in the documentation a way to specify the file type options during job submission. If for example, I specify a filename of "path\test_.png", each slave will write out a png using the png options saved in that machines own 3dsmax.ini. This can cause a bit problem if some machines are set to output 48bit, others are set to 24 bit, and others still may have the alpha disabled! (btw, Combustion crashes if a sequence does not have identical bit depths for every frame!!!)
One of the things my job submission script does is attach a #preRender script to each job submitted. (using callbacks.addscript #preRender) I know that my script is being properly applied and executed because it's doing lots of other things to the scene, including updating materials, changing object properties, etc. I had the bright idea of using the bitmapIO options to modify the file output settings on each slave in the #preRender script. For example, I added the following lines as a test:
But to my dismay, the render slaves output the same chaotic mix of 24 and 48 bit that they did before, instead of 8 bit grey as I specified. Am I doing anything wrong? Is #preRender the wrong place for changing output options? Do changing the bitmapIO options even do anything?
Any help is appreciated.
Ray
pngio.setType #gray8
pngio.setAlpha false
pngio.setInterlaced true
Ray
