Scripted Custom Attributes & DropDownLists
Hi Everyone,
First of all, if anything I mention here sounds inefficient please feel free point it out...
I'm working on a game and I need to pass information defined by the Art Team (in Max) out to our game engine.
So, I'm using Scripted Custom Attributes as a holders for this new info (that way everything gets saved with their associated object.)
The first test I did, was with a simple checkbox. It worked just fine.
Then, (because need to represent a list of predefined choices) I tried using a dropdownlist.
Here is the script...
-- Define
NewAttrs = attributes MyNewAttrs --attribID:#(0x9cf491c, 0x4c7a0cf0) --generated by genClassID()
parameters params rollout:MyAttrs_rollout
Item_Things type:#string ui:ddl_Things
rollout MyAttrs_rollout "My Attributes"
-- UI Controls
dropdownlist ddl_Things "Pick Thing" \
items:#("First Thing", "Second Thing", "Third Thing")
-- Event Handlers
on ddl_Things selected ddl_ret do
Item_Things = ddl_Things.items
format "Item_Things: %\n" Item_Things
-- Assign
custAttributes.add $ NewAttrs
The problem is that the selection that I make in the dropdownlist get's lost as soon as I change selections.
However, if I select the object and execute the following in the Max Script Listener...
$.Item_Things
The attribute that I defined is still correct, just not represented in the dropdownlist UI anymore.
Am I missing something simple here?
Because, no other UI Control lost track of it's data.
Thanx for any help you can provide.
-Red
Just thinking off the top of my head but could you drop some code into an on rollout open event to force it to be the right selection.
The problem I see immediately is that you are not storing your selection and since this UI is not persistant it doesnt remember anything. When you switch back to it, it will re-evaluate everything that you have defined there but it will not set anything because you are not setting anything in your initial evaluation here. What you need to do is add additional parameters and reference those when setting and updating your UI.
So add the new parameter storing your selection here.
// New parameter used to store your selection index
DropDown_Selection type:#int
Now reference that when updating your selection.
// Update the new Parameter
DropDown_Selection = selected
Depending on how you want to access this value when you load the UI and selections you can call the following.
on MyAttrs_rollout open do
if (DropDown_Selection != undefined) then
ddl_Things.selection = DropDown_Selection
Thanx Randall and Dan.
That worked.
