Script to apply materials to objects by name
danZL2KU
Message 1 of 24
danZL2KU
Hi
We currently link our models into 3ds max from Revit by material name. For example:
-Plywood Face Natural
-Plywood Edge Natural
We then select each of these, one by one and apply a material to them from our library.
I have set up the materials with the exact same name.
It is quite simple but it takes time to apply as we can have 20 or 30 objects/materials.
Is there a script which I can run to do this:
It would be something like this.
1. Select all objects.
2. Apply materials from a library which have a name match.
Dan
www.madeinply.co.uk
Replies (23)
Message 21 of 24
denisT.MaxDoctor
@danZL2KU wrote:
Any idea why that is?
because you do something wrong... there is only one possible reason.
name don't match exactly, not all materials in the library, path is wrong... do everything right and it will work.
Message 22 of 24
denisT.MaxDoctor
@danZL2KU wrote:
Figured it out. I have to select the objects and then run the script
you have the option to do it for all objects in the scene...
But you should have minimal knowledge of how maxscript works. So, try learning MaxScript if you're going to use it in the future. Good luck!
Message 23 of 24
danZL2KU
Not to worry I have figured it out. Thank you so much for your help. This works so well.
Message 24 of 24
denisT.MaxDoctor
 Solved by danZL2KUGo to Solution.
Haha... You forgot to 'Like' yourself 😉
