Announcements
Script request (paid): Physical to Standard (Legacy Converter)
MatthiasGose3847
Message 1 of 1
MatthiasGose3847
I'd need a script for bulk converting imported materials from FBX.
When I import I have a physical material. It has assigned a texture map on base color, roughness and a bump map with a normal bump map (and depencies).
What I need now is this:
1. Convert this material and its name to standard (legacy)
2. apply the base color map to diffuse color
3. apply the roughness map to glosiness
4. apply normal bump to bump
Should also work in multi/sub
If u can help please leave me a note which the budget you need.
Thanks.
Replies (0)
