Announcements
Script [Random one group select per every layer with suffix *m*]
951polo
951polo
Hello everyone, I need a little help. I have a working script for a year and I got stuck in one part and I can't solve it. the script should do this: -select all layers with suffix exmp: "*m*" -random select one Group from all layers "*m*" -must not indicate objects but only groups, because random selection works poorly if "group_1"(10objects) and "group_2"(300objects).
currently the script is as follows:
run 1: layer 1 select 0 group
            layer 2 select 2 groups
run 2: layer 1 select 1 group
            layer 2 select 1 group
run 3: layer 1 select 2 groups
             layer 2 select 0 group
run 1 and 3 are bad. run 2 is correct
	----- Select layer with suffix and group ------ work
showtextg1 = "*m*"
nodesInsideLayerWithPrefix = for nodeOn in objects where isGroupHead nodeOn and matchPattern nodeOn.layer.name pattern:showtextg1 collect nodeOn
if nodesInsideLayerWithPrefix.count > 0 then
select nodesInsideLayerWithPrefix
if selection.count != 0 then
	hide $
selObjsArr = for nodeOn in objects where isGroupHead nodeOn and matchPattern nodeOn.layer.name pattern:showtextg1 collect nodeOn
if selObjsArr.count != 0 then
  layersArr = #()
  for o in selObjsArr do
  selObjLayer = o.layer
  appendIfUnique layersArr selObjLayer
objToSelArr = #()
for la in layersArr do
	la.nodes
	append objToSelArr (nodes[random 1 nodes.count])
	select objToSelArr
----- UnHide all what is selected ------ work
hiddenObjs = for obj in objects where obj.isNodeHidden collect obj
unhide selection hiddenObjs ;
iwant this result:
 Thanks for any advice.
denisT.MaxDoctor
	dict = dictionary #string
	for k = 1 to layermanager.count-1 do
		layer = layermanager.getlayer k
		if findstring layer.name "m" != undefined do
			layer.nodes &nodes
			groupheads = for n in nodes where isgrouphead n collect n
			if groupheads.count > 0 do dict[layer.name] = groupheads
	forsel = for d in dict collect d.value[random 1 d.value.count]
	if forsel.count > 0 then select forsel else clearselection()
951polo
Well thank you.
