Announcements
save file
save file
save file
Hi I have a problem with my 3ds max 2017 ,  my 3dsMax save the file when I press i don't save, any Ideas with this issue ?
me too :((((((
It is a virus of 3dsmax. You install this script. It will solve your problem.
http://3dground.net/prod/prune-scene-2180817
malcomarmstrong
Dont install any script. Its not a virus. Check your preferences to see if the autosave/autoback is set to on. If this is not the cause, check other forums before you install any script as a fix.
preben
I have the same issue in Max 2019. If I open a scene and I regret what I changed, close the program and press "No" for saving, it starts saving anyways and replacing the Max file with a new save. The Autoback is switched off. Anyone knows why this is happening?
