Run multiple 3ds Max simultaneously with dedicated CPU threads for each
Babak.njf
Babak.njf
I have a python script to build meshes in max. Because multiprocessing won't help and they don't need to be in a single max project, I want to run multiple 3ds Max apps to execute this script individually for each section to speed up the whole process. But for example running 2 apps slows down each process, almost twice slower.
How is it possible to run each 3ds max with dedicated and separate thread/s!? or is there another solution!?
senorpablo
That doesn't make sense to me. How many cores does your CPU have?
I run multiple instances of Max to do processing with maxscript tools, and the performance is linear. I can run about 10 instances on my 6 core/12 processor machine before maxing out the CPU and noticing a performance hit on any of the individual instances of Max.
Perhaps the python portion of the work is the bottleneck, and python is multithreaded?
Babak.njf
Hey, thanks for the comment.
I just did a quick test with a simpler maxscript (and also the same python version) with the run of 5 instances and as you said pretty much the same speed.
I got the same 6 core/12 processor. The main python code is not multithreaded, but gets the input data from the cloud. This could be the problem, or loading the maps from the local drive. I am troubleshooting to find out the issue.
Thanks again
Cheers
