Rotate UVW +90 & -90
I'm trying to rotate a selected face via maxscript +90 degrees and -90 degrees in the Unwrap UVW Modifier.
I can mirror using...
$.modifiers.unwrap.mirrorv ()
$.modifiers.unwrap.mirrorh ()
But can't figure out how to rotate +90 and -90, listener doesn't pick up anything when I use the rotate buttons in the Unwrap dialogue.
tia
PiXeL_MoNKeY
From the maxscript help > Unwrap_UVW > Transform Selected:
<void><Unwrap_UVW>.rotateSelectedCenter <float>angle
Rotates the selected sub-objects at the specified angle using the selection center.
<void><Unwrap_UVW>.rotateSelected <float>angle <point3>axis
Moves the selected sub-objects at the specified offset about the specified axis.
The second one should be rotates, but that is copied direct from the Maxscript Help.
-Eric
Thx Eric...that's the code i was trying to get to work, but in that format makes no sense to me.
I rotate in the Unwrap uvw with angle snap set to 90 degrees, and get this from the listener....
$.modifiers.unwrap2.RotateSelectedCenter 1.85878
$.modifiers.unwrap2.RotateSelectedCenter 0.933751
$.modifiers.unwrap2.RotateSelectedCenter 1.19555
$.modifiers.unwrap2.RotateSelectedCenter 1.14319
$.modifiers.unwrap2.RotateSelectedCenter 0.898845
$.modifiers.unwrap2.RotateSelectedCenter 1.40499
$.modifiers.unwrap2.RotateSelectedCenter 1.62316
$.modifiers.unwrap2.RotateSelectedCenter 1.16064
$.modifiers.unwrap2.RotateSelectedCenter 1.78024
$.modifiers.unwrap2.RotateSelectedCenter 1.46608
$.modifiers.unwrap2.RotateSelectedCenter 1.13446
$.modifiers.unwrap2.RotateSelectedCenter 1.37881
It seems to work, but I'm not sure how precise the 1.85878 is or what value to use for a precise 90 degrees.
thx
Ahh...s'ok got it fixed.... I typed "90 degrees in decimal" in google and got 1.57079633 🙂
That's much better 😉
thanks
Steve_Curley
2*PI radians = 360 degrees.
2*PI/4 = 1.57079633 = 90 degrees 😉
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
PiXeL_MoNKeY
Or simply use the built in conversion tools:
Angle Conversion Methods
degToRad <number>
Returns the conversion of the number from degrees to radians. The result is always a float.
radToDeg <number>
Returns the conversion of the number from radians to degrees. The result is always a float.
A lot of the time when it comes to rotations the values will be a float radians rather than degrees.
$.modifiers.unwrap2.RotateSelectedCenter (degToRad 90.0)
-Eric
Thx guys, that's comprehensively covered, and it works a treat.
