Rotate Multiple Objects Around a Common Center
experimentaldJ
Message 1 of 8
experimentaldJ
Rotating multiple objects around a common center inside of 3ds Max is easy. Select everything, rotate.
How do you accomplish this in maxscript?
I've figured out how to rotate my selected objects one at a time around the selection center, but that is not the same as rotating them together. The selection center moves after rotating one object so the rest are rotated around a new selection center.
Replies (7)
Message 2 of 8
denisT.MaxDoctor
see the MXS help about
The about <center_spec> context is the MAXScript equivalent of the rotate/scale transform center list on the main 3ds Max toolbar.
delete objects
--seed 0
for k=1 to 5 do (teapot radius:(random 10 60) pos:(random -[100,100,100] [100,100,100]))
center = random -[100,100,100] [100,100,100]
point pos:center wirecolor:green
rotate objects (eulerangles 0 0 45) about center
Message 3 of 8
experimentaldJ
Sorry I should have been more clear. I need to rotate all objects around the selection center. I can't find anything on getting the "center" from "selection".
Message 4 of 8
denisT.MaxDoctor
rotate selection (eulerangles 0 0 45) about selection
did you read the help?
or about selection bounding box center:
rotate selection (eulerangles 0 0 90) about (selection.center)
Message 5 of 8
experimentaldJ
Neither of those work...
Message 6 of 8
denisT.MaxDoctor
if it doesn't work, it means you're doing something wrong...
Message 7 of 8
experimentaldJ
The correct line is:
about (selection.center) rotate selection (eulerangles 0 0 90)
Message 8 of 8
denisT.MaxDoctor
c'mon ... what's the difference? 😉
