Announcements
Right Click Menu (Alternative to Quad)
andrew.speed
Message 1 of 8
andrew.speed
I've currently got a script that runs on start up and constantly checks if the right mouse is pressed or not.
If true then it will open a custom marker menu. I ultimately want to be able to use octopus 2 or radially for the menu.
I wanted some advice on optimising this script? I'm also not sure of how to close the menu once the right mouse button is released. any help would be most appreciated
MenuActive = false
fn SetMenuActive =
	MenuActive = True
   fn SetMenuInActive =
	MenuActive = false
	theTimer = dotNetObject "System.Windows.Forms.Timer"
   fn checkRightMouseButton =
	print MenuActive
	if mouse.buttonStates[3] == true then
		if MenuActive == true then
			else
			SetMenuActive()
					if Selection.count == 0 then
					OctopusInterface.StartOctopus "RCNoObject"
					else
					OctopusInterface.StartOctopus "RCObjectMode"
		else
		SetMenuInActive()
   dotnet.addEventHandler theTimer "tick" checkRightMouseButton
   theTimer.interval = 100
   theTimer.start()
Replies (7)
Message 2 of 8
denisT.MaxDoctor
In 3DS MAX, the right mouse button is very active in many different operations. Using pure Right Click (Press) event to activate some custom interface solution is completely wrong approach.
It's hard to believe, given how much work has been put into Octopus, that it doesn't offer a convenient mechanism for activating it.
Message 3 of 8
istan
Polling mouse click events is for sure the wrong approach.
I see only one professional solution:  Maybe AD is already using QT menus in C++, which could probably be overwritten by a different visualization method. Otherwise you would have to rebuild all integrated Max RMB menus. Additionally you would lose all RMB menus from 3rd party plugins.
Message 4 of 8
andrew.speed
Thanks for the reply.
Don't get me wrong Octopus can be launched by any hotkey. I just would have preferred to use mouse click.
My knowledge of Maxscript is rather limited as im sure you can tell.
I understand that this solution was rather problematic the one benefit I found to using mouse.buttonstates is it only checks when in viewport. so right clicking the rest of the ui was unaffected which is what I wanted.
on Right Click I set it to run this script. maybe this would have been better suited to be in the main script
if Selection.count != 0 and classof selection[1].baseobject == Editable_Poly then
ObjectMode = SubObjectLevel
case ObjectMode of
0: OctopusInterface.StartOctopus "RCObjectEdit"
1: OctopusInterface.StartOctopus "RCVertexEdit"
2: OctopusInterface.StartOctopus "RCEdgeEdit"
3: OctopusInterface.StartOctopus "RCBorderEdit"
4: OctopusInterface.StartOctopus "RCFaceEdit"
5: OctopusInterface.StartOctopus "RCElementEdit"
else
OctopusInterface.StartOctopus "RCCreate"
Message 5 of 8
andrew.speed
That sounds like a great solution. Though I would have no idea how to do it. My coding skills are basic in maxscript and non existent in C++.
Message 6 of 8
Serejah
Not sure about the latest ones but in older max versions you could subclass viewpanel or any other window and listen to WM_RBUTTONUP message. But I don't know how are you going to detect whether right click was used to cancel some operation or used to open the quad menu.
subclassing example
Message 7 of 8
andrew.speed
Hey, that sounds interesting.
I'll take a look.
Not being able to cancel would be an issue. however other quad menus should in theory be unaffected. The only way I have managed to make this work so far is by removing all items in the default quad menu.
so snapping quad menu etc should still work fine.
Thanks for reply.
Message 8 of 8
denisT.MaxDoctor
Super!
