Reverse project 2D point to 3D Point
I am trying to convert 2D XY point to 3D X,Y,Z points based on the selected viewport. I can assume the 3rd coordinate value as 0. I have written a function and it is working somewhat. My current issue is that my solution depends on the size of the selected viewport which I need to avoid.
My final target is, based on the selected viewport and input point, I need to move a plane so that if I render from the same viewport I get the input value as the top left point of the plane.
I am not sure what I am doing is actually right or wrong? To check I will add my function here.
Point3 point_2d_to_3d(Point2 point2d)
	Box2f safe_frame = safeframe();//calculate safe frame
	float width_ratio =  safe_frame.getW() / render_width();
	float height_ratio = safe_frame.getH() / render_height();
	float X_float = point2d.x * width_ratio;
	float Y_float = point2d.y * height_ratio;
	X_float += safe_frame.getX();
	Y_float += safe_frame.getY();
	/* converting viewport screen space point to world space*/
	IPoint2 s_point( (X_float, Y_float );
	float focal_d = viewport.GetFocalDist();
	Point3 point_3d = viewport.MapScreenToView(s_point,focal_d);
	if(viewport.IsPerspView())
		point_3d.x = point_3d.x * -1;
		point_3d.y = point_3d.y * -1;
	/* Applying camera rotation and translation to the world point */
	point_3d = inverse_camera_matrix.PointTransform(point_3d);
	{ /* Setting one of the axis to 0 based on view direction */
		Matrix3 aTM, coordSysTM;
		viewport.GetAffineTM(aTM);
		coordSysTM = Inverse(aTM);
		Point3 viewDir = coordSysTM.GetRow(2);
		if(almost_equal(fabsf(viewDir.x), 1.0f))
			point_3d.x = 0.0f;
		if(almost_equal(fabsf(viewDir.y), 1.0f))
			point_3d.y = 0.0f;
		if(almost_equal(fabsf(viewDir.z), 1.0f))
			point_3d.z = 0.0f;
	return point_3d;
Any help is very much appreciated even a maxscript will be very much helpful.
denisT.MaxDoctor
there is no a single 3D point that corresponds to a 2D screen point. it might any point on the ray that goes from camera view through the screen point.
there is mapScreenToWorldRay mxs method that gives you this ray.
Thank you for the reply. As mentioned in the question, I understood there is no single point and I can accept the value of depth as 0. Thanks for the API. I will check it.
