Reset object and remove mesh normals?
KasperFilipsen
Message 1 of 16
KasperFilipsen
I have a script that I use to reset objects, so all transforms and normals are removed from a mesh.
I've been using the code snippet below in Max 2021, which works fine. But it doesn't seem to work in 2024, the explicit normals aren't removed.
Does anyone know of a foolproof way to remove mesh normals from a mesh, that ideally doesn't require me to be in the modify panel, so I could use it even if the Max interface isn't active.
Alternatively, is there is another way to reset and object that I don't know of?
	local myArray = getCurrentSelection()
	for obj in myArray do (
		convertTo obj PolyMeshObject
		-- Adding a 'Mesh_Select' and disable it in rendering.
		local newMeshSelect = Mesh_Select()
		addModifier obj newMeshSelect
		newMeshSelect.enabledInRenders = false
		-- Add 2x Normal Modifiers on top.
		addModifier obj (Normalmodifier())
		-- The method I would like to avoid using
		-- Requires the UI to be active in the Modify panel
		local newEditNormals = Edit_Normals()
		addModifier obj newEditNormals
		select obj
		local normCount = newEditNormals.EditNormalsMod.GetNumNormals()
		local normArray = #{ 1..normCount }
		newEditNormals.EditNormalsMod.SelLevel = #object -- Exit sub-object level
		newEditNormals.EditNormalsMod.Reset selection:normArray -- Edit Normals Reset
		-- ResetXForm with PreserverNormals off
		-- Doesn't seem to make a difference
		ResetXForm obj
		obj.modifiers[1].PreserveNormals = false
		-- Create an empty object and attach the 'obj'
		local tempSpline = line()
		convertTo tempSpline PolyMeshObject
		tempSpline.EditablePoly.attach obj tempSpline
Replies (15)
Message 2 of 16
MartinBeh
I am not sure I entirely understand your issue but the Edit_Normals modifier is the place to go for modifying normals, and ironically the Autodesk developers have gone to great lengths to make sure explicit normals do not get reset by the various modifiers, like in the old days where a "Turn to Poly" would recalculate all normals.
Your code does multiple things but if I focus only on the normals aspect, this code snippet seems to do the job for me:
fn resetNormals theNode = (
	local m = Edit_Normals()
	addModifier theNode m
	select theNode
	max modify mode
	local normCount = m.EditNormalsMod.GetNumNormals()
	m.EditNormalsMod.SetSelection #{1..normCount}
	m.EditNormalsMod.Reset()
	convertTo theNode Editable_Poly
... which is fairly similar to what you already have, but as you wrote in your message (and your code comment), this does indeed include to switch to Modify mode, with the object selected, which can be rather slow. But as far as I know that is a limitation of the Edit_Normals modifier.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 3 of 16
MartinBeh
Short update:
Here is a fast way to nuke all the normals. It might be a tiny bit dangerous if you have some geometry with unwelded vertices but otherwise it seems fast and does not need the Modify panel 😉
fn killExplicitNormals theNode = (
	addModifier theNode (Vertex_Weld threshold:0.0)
Does that solve your problem?
Message 4 of 16
klvnk
the Turn To Poly Modifier doesn't support (or never used to) expilicit normals so will remove them and as you're converting to editable poly anyway.
Message 5 of 16
MartinBeh
This works for older versions of 3ds Max but as far as I remember this was fixed with the newest releases of 3ds Max, so Turn To Poly (and most other modifiers) will not longer invalidate explicit normals.
Message 6 of 16
denisT.MaxDoctor
We know what you want to remove(reset) - transforms and specified normals. The question is, what do you want to keep? 🙂
Message 7 of 16
denisT.MaxDoctor
deleted
Message 8 of 16
klvnk
looking at the source code between 2010 and 2025 there is no difference, but should be pretty easy to for someone with 2023/24/25 to check. It still strips explicit normals in 2020 btw.
Message 9 of 16
denisT.MaxDoctor
MAX 2023 ... the Turn to Poly preserves specified normal now. There is no option to reset
Message 10 of 16
denisT.MaxDoctor
Of course, that can't be the solution. It just welds normals, which is no close to reset.
Message 11 of 16
denisT.MaxDoctor
g = (dotnetclass "autodesk.max.globalinterface").instance
inode = g.COREInterface14.GetINodeByHandle $.inode.handle
obj = (inode.EvalWorldState g.COREInterface.Time true).Obj
obj.Mesh__TriObject.ClearSpecifiedNormals()
update $
Message 12 of 16
klvnk
yeah looks like it's been added to the MNMesh Copy assignment operator and AddTri i guess.
Message 13 of 16
MartinBeh
Of course it is a hack, but I am not seeing it "welding normals", rather welding vertices (at zero distance threshold) and recomputing normals. And isn't that what is needed here?
The result of "weld 0.0" looks identical to the result of the dotNet code you posted.
Message 14 of 16
denisT.MaxDoctor
Well... It looks like your trick is working. To be safe, we can add “Don't Weld Sel Edges” and select them all.
I hadn't considered welding the vertices for obvious reasons, but I forgot about the “protection option” for the selected edges.
Message 15 of 16
denisT.MaxDoctor
Now in the context of the improvements made to preserving specified normals in several modifiers, we should probably consider the work of the Welder as a bug and report it as a bug 😜
Message 16 of 16
KasperFilipsen
I mainly want to just keep the mesh, the smoothing groups and the UV's, everything else should be disregarded.
