Requirements to access external parameter blocks?
Now that I am able to successfully create my object plugin from my utility plugin, I want to be able to control the object's parameters from the utility. utiltest.cpp contains an example in which a created cylinder's height and radius are accessed using the following:
Object *obj = (Object*)ip->CreateInstance(GEOMOBJECT_CLASS_ID, Class_ID(CYLINDER_CLASS_ID,0));
assert(obj);
IParamArray *iCylParams = obj->GetParamBlock();
assert(iCylParams);
followed by a series of parameter statements in the format of:
int param = obj->GetParamBlockIndex(INDEX_INTEGER);
assert(param>=0);
iCylParams->SetValue(param, TimeValue(0), value);
to set the initial values.
Using this code as-is, I can make my own utility create a cylinder like the sample file. However, when I try to substitute my own plugin object, I get the error:
Assertion failed!
Program C:\...etc.\...c.pp Line: ###
Expression: params
For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts
(Press retry to debug the application - JIT must be enabled)
In which Line: ### refers to the line of the statement
assert(params)
My object base class includes the methods:
int GetParamBlockIndex(int id) { return id; }
IParamBlock2 *GetParamBlock(int i) { return pblock; }
IParamBlock2 *GetParamBlockByID (BlockID id) { return pblock->ID() == id ? pblock : NULL; }
and the source file contains the following:
enum { obj_params };
enum { obj_size };
static ParamBlockDesc2 obj_pblock (
obj_params, _T("ObjectParameters"), 0, &ObjDesc, P_AUTO_CONSTRUCT + P_AUTO_UI, PBLOCK_REF,
IDD_PANEL, IDS_PARAMS, 0, 0, NULL,
obj_size, _T("size"), TYPE_WORLD, P_ANIMATABLE, IDS_SIZE,
p_default, 0.0f, p_ms_default, 10.0f,
p_range, 0.0f, float(1.0E30),
p_ui, TYPE_SPINNER, EDITTYPE_UNIVERSE, IDC_SIZE_EDIT, IDC_SIZE_SPIN, SPIN_AUTOSCALE, p_accessor, &ObjDesc, end,
end
The object in question is of the HelperObject type, and its parameters work internally (it can be resized using a spinner).
What is most likely causing the Assertion Failed error? Is there something I need to add or change in my object source code to make it properly accessible by my utility? Or is there something that I need to add to my utility plugin to allow it to access my object?
istan
Could you please post your code? From what you have written, it's not clear to me what exactly you did. You are on the right way at least.
Istan
