Announcements
RenderBitmap can't export correctly when the BitmapTex with output info
jeremyliu1989
Message 1 of 1
jeremyliu1989
Hi, all:
 I have tried to export bitmap from texmap with the function RenderBitmap of MaxPlus. The code is as follows:
    bitmap_filename = 'test.jpg'
    # Create a bitmap
    rendbm = MaxPlus.Factory.CreateBitmap()
    # BMM_TRUE_64 = 7
    BMM_TRUE_32 = 6
    storage = MaxPlus.Factory.CreateStorage(BMM_TRUE_32)
    # Now we can get the bitmap info
    info = storage.GetBitmapInfo()
    # Set some common properties on the bitmap
    info.SetWidth(1024)
    info.SetHeight(1024)
    # Set Gama
    info.SetGamma(1.0)
    info.SetCustomGamma(1.0)
    info.SetBitmapType(BMM_TRUE_32)
    # Allocate storage for writing to the bitmap
    storage.Allocate(info, 2)
    # Set the storage on the bitmap
    rendbm.SetStorage(storage)
    # Set the bitmap output base file name
    info.SetName(bitmap_filename)
    texmap.RenderBitmap(rendbm,1.0,True,MaxPlus.Now())
    rendbm.OpenOutput(info)
    rendbm.Write(info)
    rendbm.Close(info)
However, it could not export the correct image when the output of BitmapTex is set, such as inverted or RGB offset and so on. Seems that it can't recognize the output info.
Is anybody facing the same problem? Any suggestion is appreciated in advance.
Replies (0)
