Python: apply material from materiallibrary to node
Hi all !
I'm trying to apply a material loaded from a material library to a node
The steps:
1. MaxPlus.MaterialEditor.LoadMaterialLibrary
2. matlib = MaxPlus.MaterialLibrary.GetCurrentLibrary()
3. loop through matlib to get specific material
4. node.SetMaterial(mat)
I get the following error on step 4 : TypeError: in method 'INode_SetMaterial', argument 2 of type 'Autodesk::Max::Mtl'
MaterialLibrary seems to return MtBase class (node.GetMaterial returns a Mtl class) so I pressume this is the problem ?
Anyone knows how I can fix this ?
Thanks !
Johan
danielkenobi3d
You are missing the cast before assigning. 😄
SubAnim = MaxPlus.MaterialLibrary.GetMaterial(MatLib,matInde x)
refMat = SubAnim.GetRefTarget()
Material = MaxPlus.Mtl._CastFrom(refMat)
danielkenobi3d
So here is the thing. I am trying to set up a value of undefined,
Just a simple test with materials.
I run the following code
Code:
import MaxPlus
selection = MaxPlus.SelectionManager.Nodes
for i in selection:
    g = i.Material
    print g
if the object has a material will print
Animatable(VRayMtl)
if the object doesn´t have a material will print None
but if I try to run the following code (when the object has a material).
I will run in the following error
import MaxPlus
for i in selection:
    i.Material = None
>> MAXScript MacroScript Error Exception:
-- Runtime error: Line 6487 SetMaterial()
<type 'exceptions.ValueError'> invalid null reference in method 'INode_SetMaterial', argument 2 of type 'Autodesk::Max::Mtl' <<
So the question is how come the value of the material is None when it doesn't have the material assigned, but if i try to assign this value directly I get an error. what am I missing? any help here will be appreciated.
