Announcements
pymxs runtime implementation of MaxPlus.Core.GetRootNode() ?
Hello!
As my title indicates, I'm wondering if there's a runtime implementation of the GetRootNode function in MaxPlus, specifically I would love to know if there's a way to traverse the children of the root node.
https://help.autodesk.com/view/3DSMAX/2017/ENU/?guid=__developer_maxplus_python_api_introduction_wor...
Kind regards,
Martin Allers
eric.brosseau
Martin,
Thank you for your question.
If you strictly want to use pymxs in your Python script, here is the way to do it:
from pymxs import runtime as rt
def getRootNode():
    rootScene = rt.rootScene
    worldSubAnim = rootScene[rt.Name('world')]
    return worldSubAnim.object
def outputNode(n, indent = ''):
    print indent, n.Name
    for c in n.Children:
        outputNode(c, indent + '--')
if __name__ == '__main__':
    outputNode(getRootNode())
This code was inspired from the maxscript documentation.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMa...
and
https://help.autodesk.com/view/3DSMAX/2019/ENU/?guid=GUID-3F9BC35F-918C-46C6-8617-7DCDDD62FCE3
Hope it helps.
Eric Brosseau
Senior Software Developer, 3ds Max, Autodesk
Worked like a charm, thank you very much!
