Pymxs Custom Attributes
colbey82
colbey82
Trying to use pymxs to add custom attributes and I can't seem to find any reference to how this works.  Is it even possible?
The only reference to custom attributes seems to be here in the Documentation:
https://help.autodesk.com/view/3DSMAX/2020/ENU/?guid=__developer_using_pymxs_pymxs_objects_html
For example this is my maxscript code:
ca = attributes test
	parameters main rollout:params
		fx_shader type:#string ui:shader default:"Test"
	rollout params "REALTIME"
		edittext shader "FX Shader" readonly:True
print ca
CustAttributes.add $ ca
Is this possible to do in pymxs?  And if so how?
attilaszabo
Hi @colbey82 ,
Unfortunately pymxs does not support defining custom attributes in Python.
But you can use the pymxs.runtime.execute() function to pass in the definition of a custom attribute, as a Maxscript string, and then use pymxs to add instances of it to objects.
Here's an example:
from pymxs import runtime as rt
selObj = rt.selection[0]
testCA='''attributes "TestCustAttrib"
param1 type:#float ui:spinParam1 default:10 animateable:True
rollout params "Test Parameters"
spinner spinParam1 "Param1" type:#float
attr = rt.execute(testCA)
rt.custAttributes.add(selObj.baseObject,attr)
selObj.TestCustAttrib.param1 = 21
After you execute this python code, the selected object will have a custom attribute instance named "TestCustAttrib" with one parameter called "param1" which will be visible in the rollout called "Test Parameters" displayed in the Modifier panel.
I hope this helps,
Attila Szabo
Product Owner, 3ds Max
colbey82
Yeah this is how I normally do it, I was just looking to see if there was a pymxs way of doing it.  Might be useful to include this in the documentation so it's a bit easier to find the information.  It's very hard to find decent reference what does and doesn't work in pymxs and having practical examples is useful.
Nick
attilaszabo
Thanks for this feedback. We'll make sure this is explained in the Python (pymxs) help
Attila Szabo
