Announcements
Procedural object with animation?
Message 1 of 1
Hi all,
I need to make a script (SDK or plugin with actionscript) that creates a set of preanimated objects. This object could be for example a bird with texture and animated bones. I could then create several of them at the same time through a plugin and play with some parameters of my UI to place them in space, change the flight speed and so on.
I have seen some tutorials in SDK help to make a procedural object but it's only a set of vertices or a .x object without animation.
How could I create and import later through a plugin an animated object and change some parameters through a custom UI?
Thanks guys for your help 🙂
PS: Is there any good place for learning SDK except help files of max?
Replies (0)
