Problems with some splits
Hello again,
I'm trying to do some splits, but I can't get it. Maybe you have an idea.
Here is the case:
I have a box called "base" and another one called "box_1" that follow the base, but with some free spaces called "space" with value 10 mm.
I want that if I change the value of the "splits", the left boxes of the "base" to be split it according to the "splits" spinner values and keep those free spaces.
I have a pice of code, too, but it works only with the "Splits" values 0 and 1. After 1 it's a disaster.
Here it is:
b=200.0 -- The base
space= 10.0 -- space between boxes
s=1.0 -- Splits
rollout Split "Split"
    label lbl1 "Base height:" pos:[10,9] width:86 height:13
	spinner Base "" pos:[96,8] width:56 height:16 range:[0,10000,b] type:#worldUnits
	label lbl2 "Splits:" pos:[8,33] width:86 height:13
	spinner splitCount "" pos:[94,32] width:56 height:16 range:[0,10000,s] type:#worldUnits
	button Create "Create" pos:[8,64] width:144 height:48
on Base changed val do (b = val)
on Base entered do (b = Base.value)
on splitCount changed val do (s = val)
on splitCount entered do (s = splitCount.value)
on Create pressed do
function SPlit eMH:0 =
if eMH == 0 then
print "0"
else if eMH > 0 then
print "More than 0"
theBase=box length:50 width:50 height:b pos: [0,0,0]
theBase.name="theBase"
box_1=box length:50 width:100 height:((b/s)-(space*2)) pos: [-75,0,(space)*(s)]
box_1.name="Boxes"
for i = 2 to eMH do
nextBox= copy box_1 pos: [-75,0,(i-i)
SPlit eMH:(splitCount.value)
   )--end create
theNewFloater = newRolloutFloater "Sp" 170 150
addRollout Split theNewFloater
Something is wrong. I have no idea how to do this. I tried so many ways, but I'm stuck.
I would appreciate if you could help me.
Thanks !
har1sf0x
  I am not sure what do you want to achieve with eMH==0 but you should better change your SPLit function with this:
fn SPLit eMH:0 =
	if eMH == 0 then
		print "0"
	else
		print "More than 0"
		theBase=box length:50 width:50 height:b pos: [0,0,0] name:"theBase"
		boxHeight = ((b-(2*space)) - eMH*space)/eMH
		prevPos = [-75,0,-boxHeight]
		for i = 1 to eMH do
			obj = box length:50 width:100 height:boxHeight pos:prevPos+[0,0,boxHeight+space] name:uniqueName("Boxes")
			prevPos = obj.pos
and you should also change the spinner's slitCount type to #integer.
Enjoy,
har1sf0x
Thanks, har1sf0x !
But after I made the changes you specified, when I execute the code, I get this error:
Problem is in this line:
I suppose that "pos:prevPos" is the problem. Until there the code is OK.
har1sf0x
  You are right, i forgot the parenthesis:
obj = box length:50 width:100 height:boxHeight pos:(prevPos+[0,0,boxHeight+space]) name:uniqueName("Boxes")
Enjoy,
har1sf0x
I made 3 changes and your code works flawless !
Thanks, har1sf0x !
You are a lifesaver ! Smiley Happy
har1sf0x
Nice,
  I wrote it on my laptop and did not tested it so there were some 'bugs' 😉
Enjoy,
har1sf0x
Everything is OK. You helped me alot.
Thanks again, har1sf0x ! Smiley Wink
