Announcements
Problem While installing Apex tool for 3ds max
Hello Everyone .I am trying to install Nvidia's apex tool for 3ds max.So I downloaded the DCC plugin of apex tool for 3ds max and also Apex sdk.
So to run on max Do I have to install Apex Sdk also ?
Also after I Extracted the contents of Dcc plugin I got some files which I put into 3ds max folders .
THen when I run 3ds Max ,it gives the error
Compile error: Original macro definition not matched by source in file: D\3ds Max\Macro_PhysX_Buttons.mcr -- In line 15
I tried to find the installation procedure for apex tool but couldn't find on the internet.
I think the contents have to be moved to the 3ds max root folder e.g.
C:\Program Files\Autodesk\3ds Max 2015\en-US
C:\Program Files\Autodesk\3ds Max 2015\MacroScripts
 and so on. Just copy everything in the apex bin folder into 3ds Max's root folder
Yup I copied all the file but it was giving error in the script
Compile error: Original macro definition not matched by source in file: 3ds Max\Macro_PhysX_Buttons.mcr -- In line 15
I have the very same problem, but apparently nobody knows the answer on this site or on other sites...it drives me crazy! Is the plugin realy buggy or jut not working for a few people?
spacefrog_
Most probably you now have a mixed setup of the PhysX tools from Nvidia and the MassFX PhysX version ( which is based on an old version of the PhysX DCC tools ). AFAIK you can only have one of them installed/active at the same time, thus the standard PhysX DCC tool installer should disable the MassfX version, which seemed to be not the case on your installation
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Yeah i think you are right! I figured out the plugin is working only the toolbar gives these errors. I try to somehow disable the standard MassFx physx. Thanks!
