Announcements
paramwire float_script snafu in animating
bhnh
bhnh
Hello, all. I could sure use a little guidance on the following (here's a .swf synopsis - Float_script connections).
Here's a simple rollout that makes two boxes and point. The boxes each have a boolean custom attribute ("engage"), and a float_script is attached to the point.
ca = attributes predecessor
parameters main rollout:params
pred type:#Node
engage type:#boolean ui:btn_engage default:true
rollout params "Predecessor Test"
button btn_engage "Engage Button"
on btn_engage pressed do
engage = not engage
print engage
rollout predtest "FloatScript-ColorSwitch"
button btn_init "First Box"
button btn_next "Next Box"
local p, i=50, holder, fs
on btn_init pressed do
b = box()
custAttributes.add b ca
p = b
on btn_next pressed do
b = box pos:
b.pred = p
holder = point()
holder.parent = b
fs = float_script()
holder.position.x_position.controller = fs
fs.addNode "cube" b
fs.script = "try (with animate off (if cube.engage
then cube.pred.wirecolor = blue else cube.pred.wirecolor = red \n 0))catch(0) "
i += 50
p = b
createDialog predtest 200 60
The color of the first box is dictated by the "engage" state of the second box. It works just fine, and works when animated, as well.
OK, here's a second rollout that's identical to the first one, except that the color switch has been replaced by a paramWire tying the z_rotations of the two boxes together...
pred type:#Node
engage type:#boolean ui:btn_engage default:false
this.engage = not this.engage
print engage
rollout predtest "FloatScript-ParamWire"
b = box()
print b.engage
p = b
b = box pos:
b.pred = p
b.engage = false
-- the next few lines are needed to make the wire animatable in Max9 and higher
paramWire.disconnect2way b.pred.rotation.controller.z_rotation.controller \
b.rotation.controller.z_rotation.controller
b.engage = true
paramWire.connect2way b.rotation.controller \
b.pred.rotation.controller ("Z_rotation") ("Z_rotation")
holder = point()
holder.parent = b
fs = float_script()
fs.addNode "cube" b
then
(paramWire.connect2way cube.rotation.controller \
cube.pred.rotation.controller (\"Z_rotation\") (\"Z_rotation\")) else
paramWire.disconnect2way cube.pred.rotation.controller.z_rotation.controller \
cube.rotation.controller.z_rotation.controller\n 0))catch(0)"
i += 50
p = b
Now, the on/off feature for the paramWire works fine if you're not animating, but in animation mode it doesn't work. It malfunctions in both Max8 and Max9, so I'm assuming that the float_script is missing something. Any thoughts, please? Many thanks!
bhnh
STOP THE PRESSES! SOLUTION FOUND!! PARENT AND CHILD DOING WELL!!!
Tyson Ibele pointed out to me that the connection/disconnection of a wire parameter is not animatable, which got me out the internal feedback loop I was stuck in and led to a solution.
Rather than trying to connect, disconnect and reconnect, I tried simply multiplying one of the param expressions by a variable. When the connection is "off" the variable is zero; when the connection is "on" the variable is some float value.
pred type:#Node
engage type:#float ui:btn_engage default:2.0
disengage type:#float ui:btn_disengage default:0.0
button btn_engage "Engage"
button btn_disengage "Disengage"
this.engage = 2.0
print engage
on btn_disengage pressed do
this.engage = 0.0
print engage
b = box()
print b.engage
p = b
b = box pos:
b.pred = p
b.engage = 2.0
b.pred.rotation.controller ("Z_rotation") ("Z_rotation*"+ b.engage as string)
holder = point()
holder.parent = b
fs = float_script()
fs.addNode "cube" b
fs.script = "paramWire.connect2way cube.rotation.controller \
cube.pred.rotation.controller (\"Z_rotation\") \
(\"Z_rotation*\"+cube.engage as string)\n0"
i += 50
p = b
There's a bit of a catch to this when animating. Let's say you've got a 20-frame animation with box2 rotating. Box1 is linked at a ratio of 2:1 so both rotate. Now, at frame 10 you insert a keyframe changing the ratio to zero. What happens is that between frames 1 and 10 the ratio decrements from 2.0 to 0, so box1's rotation slows til frame 10, when it stops altogether. To achieve the on/off effect another keyframe has to be inserted at frame 9, setting the ratio to 2.0. So from frame 1 to frame 10 the ratio's 2.0, and starting a frame 11 it's zero. QED.
