Announcements
On save prompt to file properties dialogue box
luismestre
luismestre
I'm looking for some help with the following topic:
To make sure all the files have proper metadata I would like to know how to script/change/ 3D studio max to on " Save" prompt the file properties dialogue box.
This action will remind the user to fill in the fields with more metadata before closing the file.
All the help will be super appreciated.
Luis Mestre.
Luis Mestre
Oil&Gas Sr.3D & Subsea/Structural Designer
"Autodesk Autocad/Inventor & 3D Studio Max"
Email:lmsmestre@gmail.com
denisT.MaxDoctor
you can use general callback - #filePreSaveProcess (see details in the MXS Help)
you can't change the max own saving content or interrupt the saving process, but can popup a modal dialog (YES-NO) with a choice to save metadata
denisT.MaxDoctor
also you should do the same on #systemPreNew, #systemPreReset, #preSystemShutdown I guess
luismestre
Hi Dennis
Appreciate your reply however I need a bit more help ...
Can you detail a bit more ?
general callback - #filePreSaveProcess (see details in the MXS Help) ????
Luis Mestre
luismestre
I did a start ... will be possible to revise and help ?
I want the event to open the file properties on presave
Luis Mestre
denisT.MaxDoctor
fn onPreSaveFile =
	data = callbacks.notificationParam()
	if data[1] == 1 do
		k = fileProperties.findProperty #custom "LastUpdate"
		-- check something first if you really need to add or change properties:
		if (k > 0) then
			-- for example
			curr = localTime
			date = fileProperties.getPropertyValue #custom k
			/* if curr too far from last update do something like:
			fileProperties.addProperty #custom "LastUpdate" localTime
			-- or
			actionMan.executeAction 0 "40374" -- open file property dialog
		else
callbacks.removeScripts id:#my_fileprops_callback
callbacks.addscript #filePreSaveProcess "onPreSaveFile()" id:#my_fileprops_callback
here's what you can do...but you have to find a place to put this callback definition. Usually people use some startup ms file, but there may be other options.
luismestre
Thanks Dennis.
It works for the purpose.
Luis Mestre
