normal map AND shader
Message 1 of 1
is it possible to create a plugin that allow the user to use a normal map for an object, and then to choose a shader (cel-shaded, x-ray, wire frame...) which will use the normals of the normal map?
Thank you very much for your help.
Dahoo.
Replies (0)
