Need Maxscript help reading values from a csv
Message 1 of 9
So here's my code.  I need to read in values from a *.csv and make an object move up and down while rotating.  Essentially I'm trying to have a box bob up and down on a sinusoildal wave created from another program.
 AssyFile = openfile "C:\Documents\3dsMaxDesign\Scripts\\MotionTest.csv"
 set animate on
 if (AssyFile != undefined) then
  skiptonextline AssyFile
  select $Box001
  while not eof AssyFile do
   TransformName = readdelimitedstring AssyFile ","'
   XRot = readValue AssyFile
   ZTrans = readValue AssyFile
   sliderTime = 0
   max set key keys
   sliderTime = sliderTime + 15
   move $ [0,0,ZTrans]
   rotate $ (angleaxis XRot [1,0,0])
 else
   messageBox "Open Failed" title:"Error!"
My spread sheet reads like this
TransformNameXRotZTrans
1101
2101
3101
4101
5101
600
7-10-1
8-10-1
9-10-1
10-10-1
11-10-1
1200
I get this error
--Syntax error: at end of script, expected end of literal
--In line:   )
I've no idea what this means or what's wrong.  Any help?
Replies (8)
Message 2 of 9
Steve_Curley
Well, if that is the actual csv file then there are no commas in it, yet you're
which has 2 issues. The trailing single quote, and the fact that you're asking it to look for a comma when there aren't any. Also, as that first field is a number you don't need readDelimited anyway, just read a temporary variable as you've done with XRot and ZTrans.
You don't need to select the Box in order to set keys on it. Neither do you need "max set keys" - just move it and rotate it.
You're resetting SliderTime to 0, then adding 15 to it every time around the loop. Result - all the keys will overwrite each other on frame 15 resulting in just one movement.
Max Design has different default settings for animation. Customise > Preferences > Animation (tab) > Auto Key Default Frame (section) > On and 0 for this to work as expected.
And a tip for pathnames - be consistent, and use single forward slashes (a la unix/linux) rather the one (or 2) backslashes. Those will bite you eventually - the forward slashes just work.
local st = 1
local theBox = $Box001
AssyFile = openfile "C:/Documents/3dsMaxDesign/Scripts/MotionTest.csv"
	with animate on
			TransformName = readvalue AssyFile
--			format "tn=% X=% Z=%\n" TransformName XRot ZTrans
			at time (st * 15)
				move theBox [0, 0, ZTrans]
				rotate theBox (angleaxis XRot [1,0,0])
			st += 1
else
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 9
Thanks a bunch, I'll try to get that working.  As for the csv I copied it from excel, hence the lack of commas.
Message 4 of 9
First it worked great, then I couldn't get the file to read.
I tried
AssyFile = openfile "C:\Scripts\\Motion.csv"
AssyFile = openfile "C:\Scripts\Motion.csv"
AssyFile = openfile "C:/Scripts/Motion.csv"
but I keep getting a read fail error.  What gives?
Message 5 of 9
Sorry it was reading all 3 ways before I closed max and reopened.  Now it won't read any.
Message 6 of 9
Steve_Curley
Permissions? Does the file actually exist in that location?
The only thing I see wrong with the code (my fault) is that there's no close of the file. This can cause the number of available file handles to reduce every time you run the script. Windows does have a finite number of handles for open files - maybe a reboot will fix it?
			st += 1
	close AssyFile -- missing this line
else
Max 2016 (SP1/EXT1)
Message 7 of 9
Yeah the file is there.  I had it in several locations because I got the same error when using the path you see.  So I moved it into what I thought was the simplest location.  It read fine and when I closed the scene and reopened it suddenly couldn't find the file.  Now I'm trying it on another computer and get the same error.  No clue why it can't find the file.  I'm using windows 7 and max design 2014 if that makes a difference.
Message 8 of 9
I just got the file to read on a network drive.  My guess is there's something wrong w/ reading the file directly when it wants to read something like MyComputer>Documents etc.  I'm not sure what to input to fix this but right now it's working if I use a network drive.  However when I try to work at home I'm lost as to what to do.
Message 9 of 9
Steve_Curley
Is it actually failing - giving you the "Open Failed" messagebox? I've tried it repeatedly here:-
AssyFile = openfile "C:/Documents and settings/Administrator/My Documents/3dsmax/MotionTest.csv"
Load a test scene, run the script, load the scene, run the script... no file errors of any kind. Max/Max Design shouldn't make a difference, W7 vs XP might, though as I don't have a W7 installation yet I can't test that.
Max 2016 (SP1/EXT1)
