Need help recompiling a plugin...
I’m posting here to ask for assistance in my attempts to recompile an older dotXSI exporter Sourceforge project so as to make some minor modifications to permit compatibility with an older game asset compiler from Raven Software called CARCASS. Regrettably, I have no C++ programming experience… (I plan on taking some formal classes soon).
The Sourceforge project is found here: dotXSI exporter for Max
The last fully working Max plugin for the game was the custom one Ravensoft made for Max 5 and released along with their game modding tools. The Sourceforge v1.7 Max6 dotXSI exporter plugin has a few issues that are causing the game compiler to vomit on exported animations.
The issues are:
1. CARCASS expects the root node to be called “model_root” not “MAXSceneRoot”
2. The v1.7 exporter does not export out the BASEPOSE transform data .
3. XYZ axis order may be an issue-- not sure… wanted to see if Issue #2 solved everything first.
Anyways, after updating the project to point to my Max8 SDK libs and Softimage|XSI 6.02 SDK libs, downloading zlib library (for zlib_static.lib) and some other necessary includes. I attempted to build a release version of the plugin project and I got the following warnings and error:
Followed by more LINK4229 errors regarding dotXSITemplates, and finally...
I'm wondering if these XSIFTK link errors are because I'm pointing to the SDK libs that come with my Softimage|XSI 6.02 and not a xsi3.0 SDK set? Any help is gratefully appreciated... I've attached the build log in a file along with some compile notes I found on the Sourceforge page.
The issues are:
------ Build started: Project: MAXExporter, Configuration: Release Win32 ------
Compiling...
BipedChain.cpp
wm3_undo.cpp
wm3_subdlg.cpp
wm3_pick.cpp
wm3_material_pick.cpp
wm3_material_dlg.cpp
wm3_material.cpp
wm3_main.cpp
wm3_io.cpp
wm3_impexp.cpp
wm3_dlg.cpp
wm3_dlg-fns.cpp
wm3_core.cpp
wm3_channel.cpp
wm3_cache.cpp
XSIExportOptions.cpp
MAXHelpers.cpp
MAXHelpers.cpp(1099) : warning C4172: returning address of local variable or temporary
MAXExporter.cpp
MAXExporter.cpp(536) : warning C4101: 'str' : unreferenced local variable
MAXExporter.cpp(597) : warning C4101: 'fext' : unreferenced local variable
EnvelopConverter.cpp
dotXSIMapper.cpp
DllEntry.cpp
Linking...
XSIFTK_static.lib(SIBCString.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(SIBCNode.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSIParam.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSIParams.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSITemplates.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSITemplate.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(XSIParser.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(SIBCMatrix.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(SIBCUtil.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(SIBCUtil.obj) : warning LNK4078: multiple '.CRT' sections found with different attributes (40300040)
XSIFTK_static.lib(dotXSINativeTemplatesWrite.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSINativeTemplatesRead.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(dotXSINativeTemplates.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(MemoryFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(BINFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(LegacyFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(ASCIIFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(BufferFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(COLLADATemplate.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(CXSIFilter.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
XSIFTK_static.lib(EulerAngles.obj) : warning LNK4229: invalid directive '/manifestdependency:type='win32' name='Microsoft.VC80.CRT' version='8.0.50608.0' processorArchitecture='x86' publicKeyToken='1fc8b3b9a1e18e3b'' encountered; ignored
LINK : fatal error LNK1104: cannot open file 'sialloc_static.lib'
Build log was saved at "file://c:\Program Files\Autodesk\3dsMax8\maxsdk\projects\MAX8dotXSIexporter\Release\BuildLog.htm"
MAXExporter - 1 error(s), 34 warning(s)
---------------------- Done ----------------------
Build: 0 succeeded, 1 failed, 0 skipped
