Multiples rollout, one paramblock ?
09:46 AM
Hi all,
I'm currently having an issue when using different ParamBlockDesc to add rollouts to my modifier, only the last declared ParamBlockDesc will fill its values into the dialog. For example
static ParamBlockDesc2 basic_param_blck
0, _T("Basics"), 0, GetModifierTestDesc(), P_AUTO_CONSTRUCT + P_AUTO_UI, SIMPMOD_PBLOCKREF,
IDD_BASICS, IDS_BASICS, 0, 0, NULL,
... params definitions....
end
static ParamBlockDesc2 mesh_param_blck
0, _T("Mesh"), 0, GetModifierTestDesc(), P_AUTO_CONSTRUCT + P_AUTO_UI, SIMPMOD_PBLOCKREF,
IDD_MESH, IDS_PHYSYCAL_MESH, 0, 0, NULL,
end
Both dialogs will appear but only mesh_param_blck parameters will be filled. If I comment mesh_param_blck, basic_param_blck will correctly be filled.
Could the problem be because i'm specifying the same ClassDesc2 for each ?
Do I have to merge them into a single ParamBlockDesc to have it working correctly ? I tried to do that but how do you declare 2 dialogs in the same ParamBlockDesc ?
Thanks !
end
end
Thanks !
