Modifier plugin doesn't react to Animation.
mateusz_s
mateusz_s
I am working on the MODIFIER plugin -
everything works when I move the sliders manually
but when I try to animatethe sliders - nothing happens.
The sliders themselves are animating - the values are changing over the time.
But Modifier doesn't react to them.
Also functions like GetValidity and LocalValidity are not executed whlie the animation is playing?
I used the 3ds max Wizard Modifier template as base,
using the Modifier base class.
Thanks in advance!
mateusz_s
Ok, fixed.. I added those lines at the end of ::ModifyObject(..)  function.
_os->obj->UpdateValidity(TOPO_CHAN_NUM, ivalid);
_os->obj->UpdateValidity(GEOM_CHAN_NUM, ivalid);
