Announcements
mesh animation cache import plug-in c++ SDK
I am trying to make a 3ds max C++ plugin for importing 3d geometry (polygonal meshes) cache from other packages. Still new to the API, I found the lessons and from them figured out that I can do it using a combination of SimpleObject2 and UtilityObj.
However, I have been looking at the samples from the SDK folder, and they have confused me. Is the utilityObject necessary?
On a broad level, I need a plugin that has an interface where the user (or a script) can specify a fileName (which can be a string attribute in a parameter block), and a new mesh node is created from that file. Then the file is re-read when the time changes and the mesh is changed as a result. Is the utilityObj part required?
Can someone suggest me a good example source code for this?
istan
for quick'n dirty coding you could even only use the UtilityObj. the sdk is pretty plain and you always have access to almost everything.
