[Maxscript] netrender file name - trying to save without appended frame number
Message 1 of 1
I'm making a batch submitter that renders a series of cameras.  These cameras have their own single frame number to render at.  I want to be able to save the file based on the name I supply my script but omit the frame number at the end.
Is this possible? Does anyone know how to do this?
	function fn_netSubmit =
		local arr_camTEST = #("cam1", "cam2", "cam3")
		local arr_renderSeatSide =#("side1", "side2", "side3")
		local arr_renderSeat = #("seat1", "seat2", "seat3")
		local arr_renderFrames = #("1", "3", "7")
		local appendDate = "200707"
		local outputLocation = "some\\location\\"
		--connect
		nm.connect #manual "mtlwarml401.ca.aero.bombardier.net" platform:#64
		if nm.QueryControl #wait do
			nm.GetControl()
			exit
		if nm.getControl() == true then
			for i = 1 to arr_camTEST.count do
				job = nm.newJob()
				job.outputWidth = 3600
				job.outputHeight = 3600
				job.name = ("filename" + " " + arr_renderSeat[i] + " " + arr_renderSeatSide[i] + " " + "S" + "-" + appendDate)
				job.nonSeqFrames = true
				job.frames = arr_renderFrames[i]
				job.renderCamera  = arr_camTEST[i]
				job.frameOutputName = (outputLocation + "/" + ("filename"  + " " + arr_renderSeat[i] + " " + arr_renderSeatSide[i] + " " + "S") + ".tif")
				job.submit()
		nm.Disconnect()
	fn_netSubmit()
Replies (0)
