Announcements
Maxscript listener assistance
Message 1 of 23
I am new at maxscript and always have wanted to use it but don't know how.  Now I have a redundant application that I would like to try to use maxscript listener to do it. or write a script. (if I knew how)
Here is what i would like to do.
1. select an object
2. quadify selection (listener does not pick this up)
3. uvw map, box, uncheck Real-World Map size
4. assign material map called "stainless"
5. end
Can someone help me with this?
thanks
Replies (22)
Message 21 of 23
@drew_avis
Drew I tried your quadify mesh but that is different then quadrify all results
q = Quadify_Mesh() -- create a Quadrify modifier
addModifier t q -- add the modifier to our node
u = UVWMap() -- create a UVWMap modifier
u.realWorldMapSize = false -- same as unchecking "Real World Map Size" checkbox
u.maptype = 4 -- set to box
addmodifier t u -- add it to the node
mat = scenematerials["stainless"] -- find the scene material named "stainless"
-- note: this must exist on an item in the scene
t.material=mat -- apply the material to the node
Message 22 of 23
drew_avis
Hi, what is Quadrify All you refer to?  Is it this third party script? http://www.scriptspot.com/3ds-max/scripts/quadrifyall
Drew
Drew Avis
Content Experience Designer
Message 23 of 23
I looked at this and i dont think so becsause this has a dialog box. You don't have this on yours? I looked back as far as 2016 and it is on it.
Make a box and turn it into a editable poly then it should show up here under the modeling tools
