Maxscript help needed: Edit Poly modifer Selection
darawork
Advisor Advisor
darawork
Hi all,
I found this post interesting on the main forums.
Seems there was once code on Scriptspot script years ago, which has since gone offline.
Would anyone here be able to upgrade the code so as to work with 2023 Max?
Please inform the original writer before attempting to release it as a new script.
Tool by: Mathieson Facer
E-mail: info@mathiesonfacer.com
Best regards 🙂
Tool Name: 'Modifier Auto-Select'
Website: www.mathiesonfacer.com
Start Date: August 24, 2009
History:
	February 28, 2010 - v2.02
		- Fixed typo in selectModifier function. Was passing argument to navigateModStack function as
		findMod when in the navigateModStack definition it was actually findModifier. Was causing tool
		not to work with multiple nodes selected.
	February 26, 2010 - v2.01
		- Made it so with multiple selected objects, if it doesn't find the modifier instance
		after walking down the stack, it walks back up to the top so the user doesn't have
		the bottom modifier auto-selected.
	February 25, 2010 - v2.0
		- Cleaned up code for re-release.
		- Added functionality when multiple nodes selected.
		- Made selectModifier and selectBaseobject two different functions.
To Do:
	- To do list goes here.
Bugs:
	- List of bugs goes here.
Testing:
Test code can be placed in this area.
struct MJF_modifierAutoSelect
	uiInst,
	selectionTimer = dotNetObject "System.Windows.Forms.Timer" ,
	storedModClass = "Baseobject",
	fn createUi =
		uiInst = rollout modifierAutoSelectR "Modifier Auto-Select - facerFX Tools" width:200
			local rW = 200
			local w1 = rW * .875
			local w2 = w1 / 2
			local w3 = w1 / 3
			local spnW1 = 50
			dropdownlist modClassDdl items:#() width:(w1 * .7) height:20 align:#left across:2
			button refreshModsBtn "Refresh" width:(w1 * .28) align:#right
			checkbox searchNameCbx "Has string:" align:#left across:2
			edittext searchNameEtb align:#right width:(w2 * 1.17)
			checkbutton enableCbt "Auto-Select Enabled" width:w1 align:#center
			fn getModClassesAsStrings =
				local sceneMods = #()
				for x in objects do sceneMods += x.modifiers
				local modClassStrings = for x in sceneMods collect (classOf x) as string
				modClassStrings = makeUniqueArray modClassStrings
				append modClassStrings "Baseobject"
				sort modClassStrings
			fn toggleAutoSelect state =
				MJF_modifierAutoSelect.enableCallbacks state
				if state == false then
					MJF_modifierAutoSelect.selectionTimer.stop()
			fn updateUi =
				local modClasses = getModClassesAsStrings()
				modClassDdl.items = modClasses
				local modIndex = findItem modClasses MJF_modifierAutoSelect.storedModClass
				modClassDdl.selection = case modIndex of
					0: 1
					default: modIndex
			on modClassDdl selected val do
				MJF_modifierAutoSelect.storedModClass = modClassDdl.selected
			on refreshModsBtn pressed do
				updateUi()
			on enableCbt changed val do
				toggleAutoSelect val
			on modifierAutoSelectR open do
				updateUi()
			on modifierAutoSelectR close do
				toggleAutoSelect false
	fn launchUi =
		if classOf uiInst == RolloutClass then destroyDialog uiInst
		createDialog uiInst style:#(#style_titlebar, #style_border, #style_sysmenu)
	fn enableCallbacks state =
		callbacks.removeScripts id:#MJF_modifierAutoSelect
		if state then
			callbacks.addScript #selectionSetChanged \
				"MJF_modifierAutoSelect.startSelectionChangeTimer()" \
	fn selectBaseobject objs =
		if (objs.count == 1) then
			local baseobject = objs[1].baseobject
			if (modPanel.getCurrentObject()) != baseobject then
				modPanel.setCurrentObject baseobject node:objs[1]
	fn getModsFromObjs objs modClass =
		local allMods = #()
		for x in objs do allMods += x.modifiers
		local theMods = for x in allMods where (classOf x == modClass) collect x
		-- This filters for only the modifiers with the matching string pattern in the name.
		if uiInst.searchNameCbx.state then
			theMods = for x in theMods where \
				(matchPattern x.name pattern:("*" + uiInst.searchNameEtb.text + "*")) collect x
		-- This filters out any modifiers that do not have an instance on all supplied nodes.
		for i = theMods.count to 1 by -1 do
			local deleteMod = false
			for x in objs do
				if ((findItem x.modifiers theMods[i]) == 0) then
					deleteMod = true
			if deleteMod then
				deleteItem theMods i
		theMods
	fn navigateModStack direction:#down findModifier: =
		local lastMod = undefined		-- Needed to check if we're at the end of the modifier stack.
		while (modPanel.getCurrentObject() != findModifier) and \
			(modPanel.getCurrentObject() != lastMod) do
			lastMod = modPanel.getCurrentObject()
			case direction of
				#down: max prev mod
				#up: max next mod
	fn selectModifier objs modClassStr =
		<DOC> Selects the modifier of the specified class from the currently selected node.  Doesn't work with multiple nodes selected.
		Arguments:
			<array> objs:	An array of nodes.  Needs to be an array since it will work with "selection".
			<modifier> modClassStr:	Class of a modifier to auto-select.
		Return:
			Does not return anything.
		local modClass = execute modClassStr
		if (modClass != undefined) then
			local theMod = (getModsFromObjs objs modClass)[1]
			if (isValidObj theMod) then
					if (modPanel.getCurrentObject() != theMod) then
						modPanel.setCurrentObject theMod node:objs[1]
				else if (objs.count > 1) then
					navigateModStack findModifier:theMod
						navigateModStack direction:#up
	fn initTimer =
		-- This function is out of scope because it is being called through the timer. Need to call anything
		-- in the struct through the struct instance.
		fn callSelectMod =
			if (MJF_modifierAutoSelect.storedModClass == "Baseobject") then
				MJF_modifierAutoSelect.selectBaseobject (selection as array)
			else
				MJF_modifierAutoSelect.selectModifier (selection as array) MJF_modifierAutoSelect.storedModClass
		dotnet.addEventHandler MJF_modifierAutoSelect.selectionTimer "tick" callSelectMod
		MJF_modifierAutoSelect.selectionTimer.interval = 1
	fn startSelectionChangeTimer =
		<DOC> Rollout and timer required to call the selectMod function above because of an issue with the callback mechanism.
		Arguments:
			<modifier> modifier:	Class of a modifier to auto-select.
		Return:
		selectionTimer.start()
MJF_modifierAutoSelect = MJF_modifierAutoSelect()
MJF_modifierAutoSelect.createUi()
MJF_modifierAutoSelect.initTimer()
-- MJF_modifierAutoSelect.launchUi()
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
denisT.MaxDoctor
macroscript DTS_STACK_JUMP
	category:"DTS"
	buttontext:"STACK JUMP"
	toolTip:"Auto Stack Jump (+SHIFT Use Current Class) (+ESC Use Current Object)"
	autoUndoEnabled:off
	silentErrors:off
	struct dts_stack_jump_struct
	public
		active = off,
		this_mode,
		last_node = ok,
		this_node,
		last_edit = ok,
		this_edit,
		need_edit,
		obj_class = undefined, -- or any Modifier or SpacewarpModifier Class,
		fn is_modifier obj = superclassof obj == Modifier or superclassof obj == SpacewarpModifier,
		fn is_modifier_class obj = superclassof obj == MAXWrapper and (iskindof obj Modifier or iskindof obj SpacewarpModifier),
		fn stack_jump =
			this_mode = getCommandPanelTaskMode()
			this_node = selection[1]
			if (this_mode == #modify and isvalidnode this_node) do
				this_edit = modpanel.getcurrentobject()
				need_edit = if is_modifier obj_class then obj_class
					else if is_modifier_class obj_class then this_node.modifiers[obj_class]
					else this_node.baseobject
				if (this_edit != undefined) then
					if isvalidobj need_edit and this_node != last_node do
						if (need_edit != this_edit) do
							callbacks.removescripts id:#dts_stack_jump
							if (last_edit == undefined) then
								modpanel.setcurrentobject this_edit
								this_node = undefined
							else
								modpanel.setcurrentobject need_edit
							callbacks.addscript #modPanelSelChanged "(globalvars.get #DTS_STACK_JUMP).stack_jump()" id:#dts_stack_jump
				else
					if (last_edit != undefined) do this_node = undefined
			last_node = this_node
			last_edit = this_edit
		on create do
			last_node = undefined
			active = off
	local d
	local s = dts_stack_jump_struct
	global DTS_STACK_JUMP = dts_stack_jump_struct()
	fn enabled = isstruct (d = try (globalvars.get #DTS_STACK_JUMP) catch())
	on isEnabled return (enabled())
	on isChecked return (enabled() and d.active)
	on execute do if (enabled()) do
		if keyboard.shiftpressed then
			d.this_edit = modpanel.getcurrentobject()
			d.obj_class = if s.is_modifier d.this_edit do classof d.this_edit
			d.active = off
		else if keyboard.escpressed do
			d.obj_class = if s.is_modifier d.this_edit do d.this_edit
			d.active = off
		if (d.active = not d.active) do
			d.last_node = undefined
			d.last_edit = ok
			d.stack_jump()
		updateToolbarButtons()
Save it as a maxscript MCR file and place it in any macroscripts startup directory. After loading MAX, you will be able to find the macro. Looking at your experience, you should easily understand how to use it... or ask me for details.
And let the author correct the script above.
code has been changed due to bug fixes and improvements added...
darawork
Hi, the original Maxscript doesn't work in 2023, that's why I'm reposting it here. I'll test your Maxscripting tomorrow. Cheers dude. Looks good. It's always good to mention names. The original coder looks very OG. 🙂
Darawork
AutoDesk User
denisT.MaxDoctor
@darawork wrote:
  1. Hi, the original Maxscript doesn't work in 2023, that's why I'm reposting it here.
it's the author's problem 😎
darawork
Not if loads of users are looking for the code. It got 53 likes on Scriptspot then just died. 53 likes is a decent amount of likes on Scriptspot. That's intriguing.
Darawork
AutoDesk User
denisT.MaxDoctor
Since I took the time to write this script, I'm still interested to know what practical value it has... Could you explain it to me?
I remember being asked several times by different clients about a similar script, and I wrote several variants at different times... But this one seems to me the most elegant, despite the fact that I did not understand its practical purpose.
