12:24 AM
For the life of me I cannot figure out how to get a dialog or a rollout floater to return what I want it to. It is basically a dialog that asks the user if they want to do one of three things.
fn createQueryDialog = ( rollout messageView "" ( button overwrite_btn "Overwrite" height:24 width:80 pos:[250,5] button create_btn "Create New" height:24 width:80 pos:[250,32] button append_btn "Append" height:24 width:80 pos:[250,60] button cancel_btn "Cancel" height:24 width:322 pos:[8,88] label answer_label "cancel" visible:false on overwrite_btn pressed do ( answer_label.text = "overwrite" destroyDialog messageView ) on create_btn pressed do ( answer_label.text = "create" destroyDialog messageView ) on append_btn pressed do ( answer_label.text = "append" destroyDialog messageView ) on cancel_btn pressed do ( answer_label.text = "cancel" destroyDialog messageView ) on messageView close do ( Return answer_label.text ) ) createDialog messageView 344 130 )
I just want it to return me a string based on what button is pressed. The same as their premade yesNoCancelBox returns whatever button you press as a name.
