Announcements
MaxScript: Dialog process messages
istan
Advisor Advisor
istan
When I create a rollout and a function runs a longer script, how can I enable the dialog for letting the user press an "abort" button? In Windows there's a processmessage, but how is this done in MaxScript? I know, I could query the escape button, but all of my users unlearnt how to use a keyboard..
denisT.MaxDoctor
i would run the "long process" with a timer, and added inside the process repeatable check of some UI control for ON/OFF state
istan
Since a "Timer" message is also just a regular dialog message, I'm not sure if it's even processed..
I'll test.
MartinBeh
Is
windows.processPostedMessages()
what you are looking for?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
denisT.MaxDoctor
my first reaction was - Yes! how could i forget about windows.processPostedMessages()
and have looked in my archive... here is what i found with my own comments:
try (destroydialog progressRol) catch()
rollout progressRol "Progress..." width:200
	progressbar pb width:186 pos:[8,4]
	checkbutton start "Start" width:186 pos:[8,24]
	on start changed state do if state do
		while not keyboard.escpressed and start.state do
			pb.value += 5
 			sleep 0.5
		pb.value = 0
		start.state = off
createdialog progressRol
run this script. by pressing "Start" button you can turn ON/OFF the 'process'. everything works and looks OK while we not press "Close" window button.
if you do it during the running 'process' you will get 'lugging' for all your operations (try to edit code in the editor for example).
so you have to understand that the using of processPostedMessages is not safe in some situations
istan
Hi Martin,
this is exactly what I was looking for.
Thank you!
