Maxscript and mentalray vector problem
Message 1 of 1
Hi all,
I'm trying to batch create ps vectors through mentalray, but i'm getting stuck.
Through Maxscript I've been able to automatically turn on Contours under Camera effects:
renderers.current = mental_ray_renderer()
renderers.current.EnableContours = true
But then I want to change 'contour output' from 'contour composite' to 'contour PS':
x =(renderers.current.Contour_Output_Shader)
--Map #175:Contour Composite (contour)
classof x
--Contour_Composite__contour
Therefore this should make the output a Contour PS shader:
(renderers.current.Contour_Output_Shader) = Contour_PS__contour
-- Unable to convert: Contour_PS__contour to type: TextureMap
but it is a texturemap, see!
classof Contour_PS__contour
--textureMap
Can anyone help, lock me up in a padded cell, or point me in the direction of some mentalray via maxscript help files?
Many thanks!
Replies (0)
