maxscript 2021 #noprompt not working
karimje728KV
karimje728KV
Hello everyone,
I wrote a script that exports geometry to separate fbx files with the comand #nopromt. Unfortunately, it seems not working fine.
exportFile (ChosenFolder + "\\" + MeshFileName + ".fbx" ) selectedOnly:true #noPrompt
can anyone help?
the script is fine, it does it's job. I do get the geometry in seperate files, but it keeps on poping up the fbx export windows and I have to click enter for each geo.
if anyone has any idea, why could this be happening, please let me know.
best regards,
Karim
ads_royje
Hi @karimje728KV ,
sorry you're having this problem.
the command order is important
exportFile <filename_string> [#noPrompt] [selectedOnly:<boolean>] [using:<maxclass>]
Does it work as you expect if you change the ordering ?
exportFile (ChosenFolder + "\\" + MeshFileName + ".fbx" ) #noPrompt selectedOnly:true using:FBXEXP
karimje728KV
rediculous!
I've never had an order issue!
thanks @ads_royje
