MAX Script Listener
MAX Script Listener
MAX Script Listener
I'm trying to make a script that does a repetative task for me. The task is this:
Apply an edit mesh modifier
select all verts and weld at .005"
Select all faces
Unify normals
clear smoothing groups
set auto smooth to 25 and apply to all faces
deselect
When I try to use MAX Script Listener, it doesnt seem to capture all the settings. (Or any of them except putting the modifier on the geometry)
How do I know what listener will and will not capture?
I wasted about three hours looking in the maxscript help, and watching (trying to find) you tube videos to help, but I'm coming up empty and feeling very frustrated.
Admitedly, I know very little about python scripting, and maxscript so any help would be greatly appreciated!
Dean
Could someone please move this question to the "Programming" area? I mistakenly posted it here.
Dean
RGhost77
Pyro777 wrote:)
Is no way 😞 I don't think somebody still uses macrorecorder...
You must write your script using maxscript documentation for proper "commands".
Royal Ghost | veda3d.com
kevinvandecar
The MAXScript listener is a slave to the functionality provided from the C++ SDK side via function publishing. So in this case yes, there is missing echoing of the needed commands. Sorry for that.
Normally the best solution for Autodesk plugins is to review the documentation. The edit mesh modifier has pretty good docs, so hopefully you can find what you need there. See here for a starting point:
http://help.autodesk.com/view/3DSMAX/2015/ENU/?guid=__files_GUID_2D34BEBA_4DF3_4EC7_8E8E_4477DB6D954...
hope it helps, kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
paulneale
I would do this with modifiers instead as it is far easier.
Run this
for x in selection do
	vw=Vertex_Weld()
	vw.threshold=0.005
	addModifier x vw
	nm=Normalmodifier()
	nm.unify=true
	addModifier x nm
	sm=smooth()
	sm.autoSmooth=true
	sm.threshold=25
	addModifier x sm
Paul Neale
http://paulneale.com
Paul Neale
paulneale
Or
	addModifier x (Vertex_Weld threshold:0.005)
	addModifier x (Normalmodifier unify:true)
	addModifier x (smooth autoSmooth:true threshold:25)
Paul Neale
Paul Neale
