Max script Global variable buttons help
gibzie90
gibzie90
I have script 1 that adds button 1 to an attribute holder on object 1,
And I have script 2 that adds button 2 to an attribute holder on object 2.
When button 1 is pressed I need button 2 to match the state of button 1.
Can anyone give me an example of how to do this? Im trying to use a global variable, but I don't know how to make button 2 check button 1.
denisT.MaxDoctor
When one UI knows something about another UI, it's a very specific case.
The more general case when one property is bound to another... In 3DS MAX there is the paramWire interface.
This is a built-in mechanism, and you should try to stick to it.
delete objects
gc()
MyCA = attributes MyCA attribid:#(171717, 717171)
	parameters params rollout:params
		shared_state type:#boolean ui:ui_shared_state
	rollout params "Parameters"
		checkbox ui_shared_state "State" align:#center
a = box name:#one pos:[20, 0, 0] wirecolor:green
b = box name:#two pos:[-20, 0, 0] wirecolor:orange
custattributes.add a MyCA
custattributes.add b MyCA
paramWire.connect2way a.MyCA[#shared_state] b.MyCA[#shared_state] "shared_state" "shared_state"
/* or one way
paramWire.connect a.MyCA[#shared_state] b.MyCA[#shared_state] "shared_state"
denisT.MaxDoctor
... binding UI controls is not impossible and might make sense in a specific case. But this is a different and much more difficult task.
gibzie90
Thankyou very much, I don't know why but I hadn't even considered using wire params. Very helpful, thankyou once again
