Announcements
Max plus combine materials
elpie89
elpie89
Does anyone know how to call a method with this signature?
CombineMaterials(Mtl mat1, Mtl mat2, int & mat2Offset)
How to pass the BitWise operator?
Swordslayer
That's not a bitwise operator, it indicates you're supposed to pass that by reference rather than by value (it will save the resulting material count into the variable).
elpie89
Ok thanks, can you write a really simple example.
Because I'm really struggling with this
Thanks again
elpie89
I tried everything with this.
Asked on the forum of techartist.org, there is an entire discussion with no solution
Is this possible to do from python?
Swordslayer
Python doesn't support the option of by-reference passing and it's usually handled by the library that wants to make it available (like with ctypes.byref when using ctypes). I don't think the setup for the SWIG that wraps the C++ functions in max was done with that in mind (but don't ask me, I would never use MaxPlus in production and in general avoid python in max as it's the slowest and least stable choice you can make).
denisT.MaxDoctor
100% agree
elpie89
I'm starting to understand why..thanks Autodesk for this great tools
