Max creation graph syntax
I am trying to use MCG on max 2020 and I'm having a hard time finding about some simple ones like "Parameter", "TriMesh", and more...
Anyone knows where can I find the full syntax?
I feel like maybe I have some missing ones, because I can't find "Create box", and more simple ones
Swordslayer
'CreateBox' is now called 'Box Mesh Primitive', many nodes were renamed in 2018 to make their intent more obvious. 'Parameter' is now called 'Tool Input', 'TriMesh' is 'Mesh' etc. If you load old graph, the nodes will show with the updated names. If you're unsure whether you got the the right node, check its properties, the original name shows in the Info section:
Is there a document with all the changes? I don't have an older version of 3ds max so I can't check changes
But thanks! It was very helpful
Swordslayer
Amazing!! Thank you so much
