Match Scale syntex
Match Scale syntex
Message 1 of 9
Match Scale syntex
I am new to max script.
I have take sphere with 50.0 radius.
Spline circle take with 25.0 radius then convert it to editable spline.
I want to match scale of circle to the sphere.
Can anybody help in find out proper syntax for this ?
Thanx in advance
Replies (8)
Message 2 of 9
something like
s = sphere radius:50
c = circle radius:25
convertToSplineShape c
c.scale =
-- or ------------
bb = c.max - c.min
c.scale.x *= s.radius / bb
c.scale.y *= s.radius / bb
Message 3 of 9
Steve_Curley
With all the usual caveats about not scaling at the object level. May not be relevent in this specific case but it's worth pointing out.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 4 of 9
I know what you mean, but did you have better idea for scaling shapes?
(i exclude processing knots as option as its too complicated)
Message 5 of 9
If that help, here is a script online "Resize Splines From First":
http://www.scriptspot.com/3ds-max/scripts/resize-splines-from-first
Message 6 of 9
Steve_Curley
That would be the "proper" way I suppose, but indeed complicated.
An alternative might be to use ResetXForm<node> then CollapseStack<node> - the equivalent of what would normally be done in the viewports.
Max 2016 (SP1/EXT1)
Message 7 of 9
I have tried this script:
bb = c.max - c.min
But spline shape not matched remain as it is.
c.scale = works but for unknown parameter mesh
what should i do?
Thank you
Message 8 of 9
Yep, there is little maths mistake, next is correct:
c.scale.x *= (s.radius * 2) / bb
c.scale.y *= (s.radius * 2) / bb
and what "unknown parameter mesh" means? If your object is strored in variable then access it '.scale' prop using varName.scale, if you work on selected object then selection.scale
Message 9 of 9
Thank you so much
