Looping through selected splines to modify pivot
leeminardi
Mentor Mentor
leeminardi
With very limited scripting experience I have cobbled together the following Maxscript to modify the pivot of a selected spline such that the Z axis aligns with the first to second vertex of the spline.  The program works for a selected spline.    I have been trying to add a for loop to cycle through all selected splines with no success.
How can looping be added to the following code to cycle through and modify all selected splines?  I have tried several for-loop formats with no success.
spl = selection[1]
s = 1
e1 = getKnotPoint spl s 1
e2 = getKnotPoint spl s 2
mid12 = (e1+e2)/2
v = e2-e1
vlen = length(v)
vu = v/vlen
m = spl.transform
ftm = translate (matrixfromnormal vu) mid12
itm = ftm*(inverse m)
spl.transform = ftm
spl.objectOffsetPos *= inverse itm
spl.objectOffsetRot *= inverse itm.rotation
spl.transform
lee.minardi
drew_avis
Hi there, the "selection" object contains all the selected nodes, and you can use that.  Try this:
for spl in selection do (
	s = 1
	mid12 = (e1+e2)/2
	v = e2-e1
	vlen = length(v)
	vu = v/vlen
	m = spl.transform
	spl.transform = ftm
	spl.transform
You might want to check that spl is actually a spline before you use it, in case something else is selected as well.
Hope that helps,
Drew
Drew Avis
Content Experience Designer
leeminardi
Thank you Drew.  That does the trick!  I had done a search on the Maxscript "selection" keyword and got nowhere.
lee.minardi
