Listener Window C++
Listener Window C++
istan
Advisor Advisor
Message 1 of 19
Listener Window C++
istan
How to open the mxs listener window from C++?
I tried 'actionMan.executeAction 1 "40472"' but it does not open..
Accepted solutions (4)
Replies (18)
Message 2 of 19
MartinBeh
No idea how to open the main MXS listener, but there is also the log mechanism - maybe that is useful?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 3 of 19
istan
Ok. But I still cannot open a window to the user.
If I had to do this myself, I would rather implement my own message handling.
My hope was to simply open the Listener.
Message 4 of 19
miauuuu
So, something like this is not working:
ExecuteMAXScriptScript("actionMan.executeAction 1 40472", MAXScript::ScriptSource::NonEmbedded, TRUE, &res);
https://miauu-maxscript.com/
Message 5 of 19
istan
Interestingly 'actionMan.executeAction 0' closes but 'executeAction 1' does not open the window?! Weird..
Message 6 of 19
miauuuu
In 3ds max, when I use F11 this is printed in the Listener each time. Once it open the Listener, then it closes it.
actionMan.executeAction 0 "40472" -- MAX Script: Scripting Listener
Message 7 of 19
MartinBeh
There also is the WindowStream class - maybe that works for your needs?
Message 8 of 19
miauuuu
Here is the code:
Value*
turnOnScriptingListener_cf(Value** arg_list, int count)
	BOOL quietErrors = TRUE;
	FPValue result = NULL;
	ExecuteMAXScriptScript(_T("actionMan.executeAction 0 \"40472\""), MAXScript::ScriptSource::NonEmbedded, quietErrors);
	return &undefined;
Message 9 of 19
MartinBeh
Yes, running
in a new MAXScript also toggles the MXS Listener on and off, same what F11 does...
Message 10 of 19
miauuuu
Yep. The:
does nothing for me. It only prints FALSE in the Listener.
I think that this: actionMan.executeAction 0 "40472" is enough. There are ways to check if the Listener window is actually open, so if it is not the
can be run to open it.
Message 11 of 19
istan
Wahhh this drives me crazy - it toggles the visibility. Thanks Miauu and Martin!
Now I need a function to find out if's already open..
Message 12 of 19
istan
solved.
if listener == undefined then ..
Message 13 of 19
MartinBeh
@istan wrote:
solved.
Does that actually work? I never get anything but a WindowStream value from this global variable...
Message 14 of 19
MartinBeh
Just FYI, this seems to work well:
w = newScript()			-- create new text window
print "Hello world" to:w	-- simple way to output to new window
-- replace text of new window
h = w.hwnd
txt = "Some new text, replacing the entire window text"
-- get IntPtr to txt
marshal = dotnetclass "System.Runtime.InteropServices.Marshal"
ptr = marshal.StringToHGlobalUni txt
-- set text of new window
res = windows.sendMessage h 0xc 0 ptr
Message 15 of 19
denisT.MaxDoctor
deleted
Message 16 of 19
denisT.MaxDoctor
As I understand, you can talk about SDK, so,
maxscript.h ->
show_listener();
Message 17 of 19
denisT.MaxDoctor
IsWindow(the_listener_window) && (GetWindowLong(the_listener_window, GWL_STYLE) & WS_VISIBLE)
Message 18 of 19
istan
Hey Denis,
show_listener();
did the job. Thanks a lot !!
Message 19 of 19
denisT.MaxDoctor
@istan wrote:
Hey Denis,
show_listener();
Hey! That was my solution! 🤣
