List View Highlight disappeared!
Hi!
I've created a Batch Render Assistant tool with which you can multi-select items.
But there's a little problem.
When I select an item by clicking on the item area, this item is highlighted.
But while I go for other place to change the parameters, the item which was just selected is not selected and highlighted at all or is still selected but I can't see it's being highlighted.
You can see it in the picture below.
So, how's it happenning? Can I fix it? Or just it's supposed to be like that and we can do nothing.
Oh, I used dotNet listView.
paulneale
I always just color the .backColor property of the item once it is selected. That way it will always show. You need to make sure that you set the color back to the default when it is deselected as well.
Paul Neale
http://paulneale.com
Paul Neale
Somebody said .HideSelection property is our option and I've found it's true.
Thank you for your reply!
And another question:
Can we change the column header's color?
Can we make the checkbox's background color to be the same as the listview's background color?
