Announcements
linking spinner values
I have three spinners - hours minutes seconds - that all have minimum values of 0 and maximum values of 90, 59 and 59 respectively. Is there an easy way to have the seconds spinner looping up past 59, starting again at 0 and at the same time have minutes incrementing by 1? Also, the best way to prevent the values going past 90 (90 59 59) is to be continually checking using "on ---- changed"?
Mark
paulneale
What is driving these spinners? You can put a range on the spinners that will stop them from being
driven to far with user input but that will not stop them from being animated in the curve editor
higher or lower, for that you will need a limit controller.
> Thanks
> Mark
Paul Neale
http://paulneale.com
Paul Neale
