Message 1 of 1
Knot shift when using 'reverse'.
02:08 PM
Max 2010 SP1
The problem:
When reversing the knot order within an editable spline via maxscript the knots get rotated (shifted).
To replicate:
Create two circle shapes.
Convert one to ed-spline, select spline and click 'reverse'. Knot #1 is positioned @ 3 o'clock.
Use the simple code below to do exactly (AFAIK) the same with the other circle. Knot #1 is @ 6 o'clock.
The result:
Is this how it is or am I doing something wrong here?
I'm guessing the answer is yes, that is how it is, and pre-emptying the fact that even more code is needed to correct it but if anybody could just confirm that this is indeed the case then I'd appreciate it.
Regards.
The problem:
To replicate:
convertTo $ SplineShape
reverse $ 1
The result:
Regards.
