iterate through objects
Message 1 of 10
I'm trying to create a simple script that iterates through objects and increments a property according to object name suffix (01,02,03,04,05 etc)
01 - leave property as is
02 - multiply by 2
05 - multiply by 5 etc
for i = 1 to selection.count do
selection.property = i*5
Thanks in advance.
Replies (9)
Message 2 of 10
barigazy
something like this
fn multiplyPropByName arr prop: =
if arr.count != 0 do
for obj in arr where isProperty obj prop do
val = ""
for s = 1 to obj.name.count where (obj.name as number) != undefined do
if val.count == 0 and (obj.name as number) > 0 or val.count > 0 do append val obj.name
if val.count != 0 do
format "value = %\n" val
val = val as number
currVal = getProperty obj prop
setProperty obj prop (currVal*val)
--example
for i in 1 to 10 do Box width:10 length:10 height:2 pos:
boxArr = $Box* as array
multiplyPropByName boxArr prop:"height"
Message 3 of 10
Thanks, so much for help. While putting to amazing piece of code it returns an error: unknown property count in undefined highlighting (3rd line) if arr.count != 0 do
Message 4 of 10
barigazy
Post your example to see what is wrong.
Message 5 of 10
for i in 1 to 10 do
boxArr = $Obj* as array
multiplyPropByName boxArr prop:"viewPercent"
I'm using this for particles though.
Message 6 of 10
barigazy
If function *fn multiplyPropByName arr prop: =* first argument must by array of nodes (maxobject) e.i:
arr = selection as array
--or
arr = objects as array
--or
arr = geometry as array
--or (lights,helpers,cameras etc.)
Second argument is property string ("width", "height", "radius" etc.)
If you want to set property of some modifiers then i need to change code.
This is why i need your example, or post some screenshots
Cheers!
Message 7 of 10
macroScript OperationX category: "PFun"
val = ""
val = val as number
rollout particles_rollout "Operation X"
for i in 1 to 10 do
)--end on
)--end rollout
createDialog particles_rollout 250 100
by the way I'm using this on SuperSpray
Message 8 of 10
I'm sorry, I'm a newbie and I appreciate your help. I've already learned huge amount by your example, thank you.
Message 9 of 10
barigazy
Try now.
If you select some supersprays then script will operate on selection otherwise it will all be taken in calculation.
link superspray test
Message 10 of 10
Brilliant, thanks very much.
