Does anyone know if there's a way to ask custom attributes what rollouts it has?
If you already know the rollout's name you can access it directly like this:
ca = (custAttributes.get $ 1) -- get def instance
ca.rollout_01 -- get rollout directly by name
--> Rollout:rollout_01
showProperties ca -- ask for properties
--> .prop_01 : float -- only returns parameters
getPropNames ca
--> #(#prop_01)
Only the ca's params show up when you inspect it's properties. I want to be able to get a ca's rollouts dynamically. Is that possible?
